Initial start and tune on a friend's S2000, 5.3 swapped. Mild Comp Thumpr cam, swap headers. OLSD tune.
Made some edits to help it start-up easier, mostly to force OLSD, base RAF etc.
After a log to full temp, the Desired Airflow values came up a good bit lower than what they should have, and lower than stock values as well.
Attached is the tune and the log.initialtstartmikesecurev2.hpt81616659.hpl
Dont mind the excessively rich commanded AFR. Something funny I figured out in a later revision with the Flexfuel stuff.
The reported AFR at some point got into the 11's, but later figured out it was from my fat ass pulling the wire out of the screw terminal.
