Results 1 to 6 of 6
Thread: base tune needed!! new tuner
    Aug 2016
    3
    Im looking for someone who might have a tune I can start with. I have a 4.8 stock internals howards .572 lift cam 42 lb injectors, 102 throttle body 2" fender exit headers, ict billet intake, fuel system that should support 600hp. backed by a th350 4500 stall trans break, 9" 5.43 gears and 29x10.5x15 slicks. my plan is to start naturally aspirated and get it fine tuned and then add a on3 78/75 turbo and run e85 if needed. any thoughts or tips would be greatly appreciated. im a certified mechanic with 11 years experience but new to tuning.
    405
    2,288
    Quote Originally Posted by syraxx125 View Post
    First you give no information on the PCM you are using or the Gen of the 4.8 so without that no one can "give" you a tune. And giving tunes doesn't happen much here. People will help with specific questions but generally the people that really know how to tune sell their services. Another thing is describing your cam with only lift numbers, you might as well give no cam information at all. My tip is you will probably needt to run open loop with those headers.
    Aug 2016
    3
    using stock ecm out of a 99 chevy truck, HOWARD'S Chevy GM LS LS1 281/284 578"/587" 112? Cam Camshaft & Spring Kit LS2, 2000 to 7200 RPM im just looking for a base tune to get me in the ball park so I can take it from there.
    Jul 2015
    925
    IIRC the 99 and 2000 truck PCM's are oddballs. I remember tuning a 99 Escalade last year and there were several things PIDS and tables not supported by HPT. After some research a lot of people change to a 411 PCM for it's added features.
    Aug 2016
    3
    thank you
    thank you for the tip, will that ecm plug into the factory harness for the 99?
    Jul 2015
    925
    i believe you have to repin some of the harness. Google GM 1999 pcm swap.
