This is what i did to get rid of the dreaded flat spot or lag off idle, I disabled spark smoothing,under desired throttle area i switch from Vss to RPM,under idle spark advance i lowered the first two rows 2 degrees and raised the idle coastdown up 5 degrees in the first two rows. Now weather rite or wrong holy jesus this thing really woke up. My truck is a 2013 siverado 1500 4WD with a 5.3. I'm in no way shape or form a pro i'm like most at still learning but i asked for help and that was a joke, either no one knows or just won't tell, either way i figured it out and for me after much scanning everything looks great. I hope this helps someone with the same issue.
