04 GTO LS1, ported 243 heads, 227/230 .613 .608 Comp cam, longtube headers into a single 3.5", free-air calibrated NGK AFX after the y-pipe, transform function based on logging raw voltages during it's startup routine, OTR intake with a MAF/IAT setup, saxonpc honeycomb, Ford red top 30# injectors, Supra TT fuel pump, Corvette regulator/filter (58PSI falling to 55PSI when warm).
I feel like the tune is pretty close, but could use a little help to finish it up.
The car seems to go lean on cold starts and the occasional hot start. I thought maybe the cold was from the OLFA table being 1.00 in some of the colder ECT ranges, but I added a bit today and it didn't seem to make a difference. Should I add more here or could there be something else? I guess the reason I'm confused is because, as mentioned, it does this on hot starts as well and then will taper off to normal after a bit. My waythere.hpl log shows the lean start issue, and some cruising in MAF/VE blended mode. (Note: the fuel trims are from me adjusting my O2 switchpoints. With the switchpoints at 451mv, the car would be 14.57 (as commanded) in VE, but would drop down to ~14.1x-14.3x when running closed loop, with STFT within a few percent. I was adjusting switchpoints to see if I could get the car to trim at 14.57 in closed loop.)
For my VE table, I've noticed that I can putt around, get everything in line, make a few minor adjustments, and then drive it again a few minutes later with totally skewed results. I pulled over, got gas, and tossed the car in VE mode. This is the ve.hpl log, and aside from the idle cells, most of it looks decent. So, I halved the idle cells only (these were off from because of a change yesterday, but that's another story), and drove it around again. The ve_idle_adjust log is a hot start lean example. It pegged lean until I started driving it, and was still hovering in the 15.x range. Eventually, toward the end of the log, it evens back out. I don't understand this.
I made no other changes to VE, and loaded a MAF only tune. Did this, numbers were between 1-8%, so I multiplied by half, did it again, multiplied by half again. It was starting to rain so I decided against any more for the time being.
I copied the new MAF data into my blended tune, adjusted the switchpoints to 415mv just to see how it would trim, and drove home (wayhome.hpl). Slight lean start, but tapered off quickly. AFR is stable, but "rich". My fuel trims look decent, AFR error is a bit off, but the car drives fine.
So, questions -
Not sure where to begin with the hot start issue. I could keep adding to OLFA for cold, but I don't understand the hot start lean unless it's IAT heat soak or something?
Not sure what to do about the AFR error in blended mode, and why I can't get it to trim at 14.57 like I can in SD and/or MAF-only mode. I realize that it's only a few percent, but it seems like everyone else can actually get their tune to trim to whatever they're commanding, and I don't know why mine is off.
I realize that is sort of a wall of text, but I've been chasing my tail with this stuff and I'd love to get it dialed in before winter I've tried searching a bunch (which helped with lots of other parts of the tune), but can't seem to get this ironed out.
waythere.hpl
ve.hpl
ve_idle_adjust.hpl
wayhome.hpl
base_rtt.hpt
