Results 1 to 9 of 9
Thread: Return style fuel system (Coyote)
    When switching to a return style fuel system are these the changes that need to be made?
    Set all of the follwing to 1 in the right hand column:
    Flow rate LOW MULT vs. Pressure
    Flow rate HIGHT MULT vs. Pressure
    Offset mult vs. Pressure
    Breakpoint mult vs. Pressure
    The following set to 55:
    Inferred rail pressure
    Inferred rail pressure low
    Secondary monitor: Set to disabled.
    Just want to be sure I am doing this correctly.
    No one?
    Oct 2007
    Crawfordville, FL
    2,412
    That should take care of it.
    Eric Brooks
    HP Tuners, LLC
    May 2016
    5
    With these settings, do you set the fuel regulator pressure with or without manifold reference?
    Aug 2009
    Naples, FL
    339
    I always do it: Engine Running, vacuum line off the regulator.
    Oct 2007
    Crawfordville, FL
    2,412
    Set the pressure with the vacuum disconnected, then connect it.
    Eric Brooks
    HP Tuners, LLC
    great info
    May 2016
    5
    Quote Originally Posted by Blueprint View Post
    Why set values to 1 rather than filling the tables with the value that is already there in the 55 psi row?
    I understand the need to make the multiplier value vs pressure constant but I'm not certain that 1 should be the value.
    Oct 2007
    Crawfordville, FL
    2,412
    Quote Originally Posted by totem View Post
    Either way will work.
    Eric Brooks
    HP Tuners, LLC
