Originally Posted by
FlatTop
I noticed and did see its a 5.7 pcm flashed to a 6.1 that was supposed to run the car. The data and tune is whats in the pcm now. I understand and know the difference in reluctor wheels are different either 32 or 58 tooth for 5.7 or 6.1 It is a 6.1 reluctor wheel on the crank.
I thought they would of sent me a 6.1 pcm and don't know why not or why they didn't. I have just sent them my original 5.7 vvt pcm to flash make it work and they got my trinity tuner also so they can test it all on the bench from my undefrstanding.
Mine is an auto also, I understand others have had success doing this swap by flashing a 5.7 pcm However, those were all 6 speed cars, none as an auto. Something about the TCM Nag 1 trans and everything not being happy working together.
On the pcm in the car now is a 5.7 pcm, supposed flashed to run a 6.1 I thought the reluctor wheel was programmable with the dodge tool.
The only codes I get are the p0129 baro to low
p2167 throttle pedal
p 2166
p2116
p2115
p0633 key not programed. But it starts, I was told as it key cycles it will clear that code.
I know I said this before, but the car drove into the shop, I myself, as always careful as I drop my motors out the bottom and not pinch a wire but shit happens and if I need to trouble shoot the system as mentiond above I will. If I knew the pcm and all was really working as should it make me feel better about the work ahead.
In fact tonight I will go through the wiring right to the pcm, terminal by terminal. Id just like to know has Anyone ever done this swap and it worked ? 09 Challenger Auto. 5.7 to a 6.1 base. six speed I find, but not one auto, yet. That I can find.
Thanks Guys, I'm very persistant and never give up
FlatTop
