Need some wisdom here. I should be finally firing this project up on Wednesday, and i was curious if anyone has done a similar swap, and if so, what ECM TCM setup you used. My friend's 5.3 busted a lifter, and so we decided to swap it for a 6.0. I have both computers, and so......
1st option would be to swap all the 6.0 info into the 5.3 ecm and not worry about the TCM marriage.
2nd option would be to plug in the 6.0 ly6 ecm and assume it will automatically marry the ECM and TCM, or assume its an easy process.
My plan right now is option 1, but i'm curious on any info with marrying/pairing ECM to TCM's.
