Results 1 to 6 of 6
Thread: Lost MPVI sensors 1-4 when i upgraded how do i assign them to a gauge?
    Potential Tuner BMERETR's Avatar
    Mar 2007
    San Jose CA.
    5
    in the channels table they show up
    and in the Gauge display I see the 3 gauges but no pointer
    also in the chart I see the field but no data from the MPVI 1-4 feeds
    any help on the issue would be a huge help
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    What version was that log taken in?
    In V3 you don't use the MPVI inputs directly in graphs/charts/gauges. You use whatever parameter it is. I.e. "PLX" instead of input 1 for a wideband for example. Or fuel pressure instead of input 2 for a fuel pressure sensor as an example.
    It isn't working right for me with that log you attached, that's why I ask what version it was created with.
    The channel config you posted doesn't match what's in that log, so that has me confused. There were no MPVI inputs setup in that channel config...
    So... either you posted the wrong one or it's setup totally wrong
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    Mar 2007
    San Jose CA.
    5
    Thanks for the input
    I am sure it was 2.22
    and when I did the move to 3.xx it all went away
    the system worked well before
    I have a LC-1 on port 1
    a autometer fuel PSI on 2 old settings 0.040 - 12.5
    and a autometer vac/boost on 3 .1665 - 14.7
    im having a hell of a time getting this
    I guess im getting old
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Got it
    Yeah, so in V3 the process is a little different. Basically you will add the MPVI input # to the list of channels by right clicking and hitting add channel. Search for MPVI and the list of channels should get filtered down to just the external input #'s. Double click on the channel #'s that you want.
    Then, right click on #1 back in the channel list and select transform. This is where you "transform" the 0-5V input into a wideband/fuel pressure/methanol pressure, etc. reading that can be used throughout Scanner. Look through the list under EQUIVALENCE RATIO, and then double click on Innovate LC-1. Do not use AFR. You can make it show up as an AFR reading later regardless.. but setting it up as lambda works much better in V3.
    Here is a thread I did that goes step by step setting up a wideband. Give this a go for the WB--if you can't get it figured out I'll try to do it for you real quick and post the channel config, but it really isn't bad once you do it once.
    http://www.hptuners.com/forum/showth...PRO-Interface)
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    DEWEY-8-8-16.Channels.xml
    Try this channel list
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
    Mar 2007
    San Jose CA.
    5
    https://www.youtube.com/watch?v=9BnLbv6QYcA
    this is how I feel at the moment with this update
