I'm willing to pay money to help solve this issue. The car has a miss at 2500 rpm and only at 2500 rpm.
If i try to command an AF ratio anything short of drowning the engine in fuel it will miss at 2500 rpm. I tried backing the timing way down and it still does it. ONLY at 2500 rpm. You can see from the scan labeled "miss" the narrow bands show a quick drop in voltage along with a blip on the wideband, this is followed by a noticeable "jerk". If I command ~9.0:1 it doesn't do it but thats just ridiculous. Even at 10.0:1 and 8 degrees it does it. At 9.0:1 i have can normal timing and it doesn't do it. You can see on scan labeled "miss" at 2:37 on the scanner the AF ratio is at a respectable 11.6:1 with 7 degrees and it does it. Also at 1:44 on the scanner it does it as well with 11.0:1 and 7 degrees.
Now on scan labeled "rich", AF is well into the 9's and timing is still at 7 and it does not miss. I can even command 12-13 degrees and it will not miss as long as the fuel is rich. Doesn't make sense to me. I shouldn't have to dump fuel in order to make the miss go away, especially since just before and just after 2500 rpm it doesn't happen at respectable AF and timing settings. Makes me thing something mechanical is going on, but what?
Car has a P1 procharger and a mild comp blower cam.
miss.hpl rich.hpl
