Things to my knowledge that are turned off in the tune:
LTFT, STFT, COT turned off, MAF failed, PE tuned out, multiplier VE table at 1, deceleration full cut off tuned out.
I would now believe that the only table affecting fueling would be the VE table but changes to the VE appear not to lead to stable corrections. All changes are made under hot engine conditions and it seems that at times the same cell value can lead to lean and rich conditions.
My question here is that VE is affected by, load (vacuum) , RPM and, throttle so how can an accurate primary VE table be achieved due to the fact that throttle conditions are an undocumented variable in the tuning process?
tune and short log attached
heartmann running k10 base tune enhanced.hptlean run.hpl
