Results 1 to 5 of 5
Thread: E47 blend on LNF
    Jul 2007
    Charlotte, NC
    159
    E47 blend on LNF
    Was looking into an E blend on an LNF. I know on the LSJ ecm you can change the stoich ratio in the program for whatever you want it to be. I didn't see an option there in the LNF. I know the LNF has a lambda sensor, so will it always look for 1.0 lambda despite the fuel being used? Or is there a way to command stoich value for the ethanol blend?
    Dec 2008
    Nevada
    4,452
    nope just set the injector offset. factory sensor reads in lambda
    Jul 2007
    Charlotte, NC
    159
    It has the larger injectors in it, I set them up for that. Do I need a different offset? How do you calculate that? Thanks
    Dec 2008
    Nevada
    4,452
    whatever its tuned to for pump gas multiply it by an additional 15-20%
    Jul 2007
    Charlotte, NC
    159
    Quote Originally Posted by cobaltssoverbooster View Post
    Ok cool, so keep the maf and correction tables as they are, and change the injector offset table by appx 15 to 20 percent across the board? Thanks man
