Hi there
living in area using 100% gasoline
if i change the stoich AFR to 14.64 is that will effect on lambda?
eg:
lambda= .82
stoich= 14.08 < factory value
so the equation will be .82 x 14.08 = 11.6
lambda= .82
stoich= 14.64 < becouse using 100% gasoline
so the equation will be .82 x 14.64 = 12.0
am i right or not?
another thing
sholud i change stoic AFR max as well?
