Results 1 to 6 of 6
Thread: Lsj won't idle
    Jun 2015
    5
    Lsj won't idle
    Got my lsj back from tuner after engine build. Car idle sometimes doesn't sometimes. At idle car is at 12-15 vac and 22% throttle. When I put my foot slightly on the gas it goes to 18-22 vac and throttle position goes to 18%.
    Swapped tb to ls4, nothing. Went to new stock tb, nothing. Car is now on tune for stock tb. Still won't idle. 1200 rpm is what it's set for.
    Any ideas?
    Also I'm very new to tuning. It was done by a pro.
    But I'm learning.
    Dec 2014
    Palmetto, FL
    874
    So it didn't run right when you picked it up from your tuner? If that is the case, why does your tuner not fix it for you?
    Do you have any check engine light codes?
    Jun 2015
    5
    He said he couldn't fix it.
    No cels
    Dec 2008
    Nevada
    4,452
    sounds like hes not a pro then
    Dec 2014
    Palmetto, FL
    874
    Alright, so does it start up and run? Just dies when you let off the throttle to let it idle?
    Go ahead and post up your tune file and a log of the car if it does start up and run by throttling it.
    And include a list of modifications.
    Advanced Tuner laser_racer's Avatar
    Jul 2009
    league city tx
    461
    Probably because how the throttle is setup. If the car has a bad vacuum leak it will cause a lot of problems.
