My set-up is a 5.3 with stock heads and .650 lift springs, tu1.5 cam, stock intake with 72lb injectors and upgraded fuel system, 76mm turbo with wastegate at 4lbs. Tranny is a th400 w/ a circle d 3400 stall converter, rear is a 8.8 w/ 3.73 gears all in a 1957 chevy 210.
My issue is when I'm coming into boost around 3600 rpm the car falls on its face till it gets above 4200 rpm. I've tried changing plugs and decreasing gap but that didn't help. Before I go and dump a bunch of fuel in this area I'm having issues maybe someone can look and help out.
Also I'm just learning how to navigate through hptuners.....
