hey guys tried to start turning a mates burnout car today combo goes like this
standard vt commodore ls1 with a holley hi ram with 102mm throttle body
we drilled a 1/8th hole in the throttle blade
then was hoping to do the rus k idle tuning method
drama is couldn't get the car to start would often start then die like its failing the maf
if you reved it you could get it to go then die
trieded tinkering with the desired idle airflow to get it to run and idle
which helped the car would then start and idle without revs but then turn it off and go to start it again and the problem would be back again not starting and needing a rev to get it going
didn't think to get a log of cranking and starting heres the tune file we started with
pisstake fans mod starting.hpt
