Hello all,
I am struggling trying to change my OS from 1 bar to a 2 bar. When I open the OS tab in the editor there are no options presented, just a blank box. All other functions seem fine and I just updated the software.
Any Ideas?
Thanks,
Josh
Hello all,
Any Ideas?
Thanks,
Josh
You need to start with a stock file first. You can't upgrade a upgraded file already.
If you have the stock tune you should be able to go back to that and then choose a 2 bar OS upgrade if it's there for that computer.
It doesn't seem to matter what file I open, the OS options do not show up. Not sure what I am doing wrong.
Software is at 3.2.38, OS options still do not show.
Post the tune you are trying to upgrade.
Following. Having some similar issues. I opened up another tune that I have not upgraded the OS on and the OS box is empty.
Always make sure you are in advanced view first, then click on the calibration details tab under EDIT. It will show if someone else has upgraded to a different OS.
