Cammed base tune
I have a 216/220 601 lift cut on a 111lsa with Ls 1 1 in take valves with very little intake porting on 799 heads. Can some give me a helping hand and point me in the right direction to get a base tune for the thing. I looking through forum after forum and everyone does everything differently. Just someone point me in the right direction thanks. I'm a noob to all this.
It's easy to get help for specific questions such as "how do I setup the scanner for idle airflow logging" (even though I'm sure it's stickied). When the question requires writing a novel (this is basically "how do I tune?") and can vary wildly based on setup, you often get crickets when waiting.
...Yup, cuz there are lots of books to teach you how to tune...
You need a base tune to get it to start and start scanning? If so is there an config file that can be loaded to start with the airflow tuning
Banned
try this
kubutek mod4.hpt
its LS1 with headers, exhaust and cam - 228"/228" .576"/.576" 112LSA
should start, idle and run quite well
best regards
Yes. You should already have a base tune... All cars have them.
Follow the stickies on setting your idle first and then go from there into VE tuning at low RPMs first.
