I scanned my 2005 Corvette 6 speed. I am never getting more than 88 percent throttle and it it is always exactly 88 percent every shift. Is this normal? If not what should I check. Thanks for anyhelp you can give.
That is a GM error in the TPS PID. Use ETC TPS % instead.
Always Support Our Troops!
Thanks for the response. I am a little new to this so can you tell me what the abbreviations mean.
PID and ETC specifically.
tps-throttle position sensor
etc-electronic throttle control
gm-general motors
pid-proportional-integral-derivative if im not mistaken
So is this just a scanning issue. Is my car acctually going to WOT.
BTW. Thanks for the fast responses. This has been very helpful
GM now deciphers it differently...but yes you are going WOT & seeing 100% TPS...you just need to use a different PIDOriginally Posted by Nicodemus
Thanks for your help.
Just delete the TPS% value on the table view and replace it with ETC TPS%. You will then see 100%.
EC
