Results 1 to 4 of 4
Thread: PE Delay on VMax truck
    Sep 2015
    SC
    4
    I've been tuning my buddy's truck for awhile and suddenly I have a PE Delay issue that I cant diagnose. If you look at the log its about 1.2 seconds after it reaches full throttle. It has never done this on previous tunes or logs. It is a speed density tune.
    Mods: Circle D 3000 stall, TFS As Cast Heads, BTR Stage 2 Truck cam, TBSS Intake, 1 7/8 Headers into off road Y and 4" single exhaust, 90mm TB with XLink adapter, 5" cold air intake
    John
    13,557
    I'm not sure if the two are related but that thing is idling/running really rich, when you come to a stop or are just cruising it's got a commanded AFR of 14.68 but your wideband is showing that it's running in the 11's.
    Sep 2015
    SC
    4
    The wideband wasn't hooked up. Look at the idle fuel trims.
    Thanks for looking though
    Sep 2015
    SC
    4
    Actually I think I'm wrong. I pulled the front 02 sensor and put the wideband in that spot. That's why one bank is super rich
