Engine stalls when moving D to N with small VSS
Car is 1999 Corvette C5 AT with plenty of modifications.
Main mods are - GMPP Hotcam, Holley Wet Kit NOS and E85.
I recently swapped to E85 and only after this I noticed the following feature:
- drive more than 6 kph at no touch for gas pedal.
- move stick from D to N
- car gradually stalls and rpm drops to zero.
- this is not happening always however -- esp. if VSS is abt 60kph - no impact car continues to run and rpms stay around 1500-2000.
Notice the following topics:
- When at 0kph or very near to 0 - you may shake the stick back and forth-- works and stays alive - obviously adaptive idle takes care and keeps the car running. Limit for adaptive idle is 6kph
- Cracker values seems to have no impact - with stock values it has abt 1.0 g/s - I have in attached I have 0 on those cells -- however tested both ways and no impact.
- Both correct RAF values and abt 5+ g/s RAF values have been tested and no impact
- E85 may have no impacr at all on this -- I just noticed this after swap to E85.
What do I miss in my tune ?
One stall log with 3 stalls and one tune attached.
Stalls.hpl
E85_MAF.hpt
br Marko
