Results 1 to 3 of 3
Thread: TBSS first datalog. Need opinions
    Nov 2015
    Peckville, PA
    23
    Finally got my wideband hooked up and logging so I did two short datalogs today. One is just a short idle and the other is pull from 10-90mph. I see some knock and also seems to be running rich but I'd like to get some opinions on everything.
    P.S. The wideband seems to be logging .1-.2 leaner than actual.
    7-3-16 first with afr.hpl
    7-3-16 idle.hpl
    Notable mods are mild cam, XSPower headers, Gibson exhaust, LS1 fans, built trans with 2800 stall.
    13,565
    The idle fuel trims are still pretty negative, you could touch up the ve/maf to get that closer. And mid 11's is rich for a NA motor.
    Nov 2015
    Peckville, PA
    23
    Thats what I thought. I probably should shoot for low to mid 12s for AFRs? Also, think I should reduce timing a bit to get rid of the knock?
    2006 Trailblazer SS
    Mild cam, XS Power headers, Gibson exhaust, Godfrey Stage V trans w/FTI 2800, LS1 e-fans, Trans cooler, PLX wideband
