I've got it working fine on my '00 Z-28 M6... I left the P/N limiter set at stock and used the rpm vs gear table and set the P/N on the table to 5,000 RPM. I'm not using this to launch though. I use this feature more or less as a full throttle shift as it cuts fuel when I push the clutch in when I'm above 5,000 RPM. So when I shift at 6,000RPM the fuel cuts until I release the clutch becuase surely it doesnt take somebody that long to shift. I still have a stock clutch and it helps me out on clutch slipping issues by limiting the fuel to the engine until my clutch is fully engaged. I have used this as a launch control also but it sucks to drive around town with because as soon as your foot touches the clutch pedal the P/N limit will activate. But as long as I'm racing it works great you just have to make sure you are completely off the clutch pedal or it will set the limit back down to your set P/N limit.
