Page 5 of 5 FirstFirst 12345
Results 81 to 85 of 85
Thread: OMG what did I do... cammed my daily '10 'maro and dont know where to start tuning!!!
  1. #81
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    In the filter box putting something like [50118.238]=1 will make it only use the data when commanded lambda = 1
    Putting something like [50118.238]<1 will make it only use the data when commanded lambda is richer than 1
    So.. try those and see what happens
    You really need to be looking at charts where you can put commanded AFR and actual AFR on top of each other so you can see what's going on
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
  2. #82
    Ok, so I should log each of those separately, then tune accordingly? Should I also do [50118.238]>1 also? And what is the 50118 number for anyway? And also, are you pretty much saying there is not really a way to tune correctly without logging my wideband on hptuners?
  3. #83
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    You can log/tune areas closed loop areas outside of PE via fuel trims
    You need a WB to tune once it goes into PE, no way around it
    50118 = commanded lambda (or "EQ Ratio" as HPTuners calls it)
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  4. #84
    Yessir, I do have a wideband (Innovate LC-2) but I only have standard hptuners so I can't hook it up to the interface. Will I still be able to tune with it not connected or I absolutely need the pro interface?
  5. #85
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    I won't say that you absolutely "can't" do it, but it's def. not ideal
    Normally you'd log commanded AFR or lambda and actual AFR/lambda and use the difference to know how far you need to change MAF/VE tables
    So best you can really do is watch the gauge and try to change the tables in the right spots by the right amounts
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
