Results 1 to 5 of 5
Thread: On startup DESIRED IDLE commands 0???
    Baltimore, Md
    1,208
    If you look at temp table, DESIRED IDLE should be 850, but clearly shows 0 rpm. Then if you put the car into gear, it SLOWLY raises the DESIRED IDLE to the value in the tune????
    Anyone ever seen this or have a clue as to why it would be doing this? Comparing all the tables to a stock file now to see if something stands out But as far as I know theres a table vs temp, and then bump up for AC and fan airflow but other than that not too many other variables?
    Factory Stock 97 SS M6 13.51 @ 104.3 mph
    Stock Longblock LS1 w/ 233/238 P.S.I. Cam
    10.81 @ 126.9 Full interior, six speed on 275 radials, a decade ago
    '99 TA trunk mounted 76mm 6 Liter
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    32psi and still winding out 5th on the highway somewhere
    Baltimore, Md
    1,208
    No one?
    May 2008
    Latvia
    143
    I have the same issue sometimes
    LS1 383ci 98' FBody, turboed, 00' PCM, 4L80E, 90# FIC injectors
    110ci Nissan 200SX, 25psi, 370whp
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    Return all the P/N tables back to stock. They are only used on automatic trans vehicles.
    Russ Kemp
    Baltimore, Md
    1,208
    Quote Originally Posted by Russ K View Post
    Russ Kemp
    I did not notice that was the case in that file, its so dumb never thought to see. I flashed it with another cars program entirely and it worked out ok, so that must have been what changed it!
