Originally Posted by
jsllc
Well I tried to short cut and copy values from another tune in TQ management. in my case the car is close to a ZR1 so I thought what the heck. Used them. I was lucky. I log all changes and have 2 widebands. In my case the changes seemed to work but then I looked at the log. WOW! One bank was running 11.5 the other 17.5 under boost. Just imagine if I would have continued to run it that way. No engine. I have since went back to stock and spent the time to make small changes repetitively until I was close to what I wanted without the side effects. That section is just not documented well. Nor is the TPS area you are messing with. Better to be lucky than good. Most have very negative experiences doing what is done to your car with the throttle.
