Page 19 of 23 FirstFirst ... 9151617181920212223 LastLast
Results 361 to 380 of 459
Thread: VCM Suite 3.2 is here!
  1. #361
    Tuner Monty's Avatar
    Apr 2012
    173
    Once you use V3 or newer there is only one version of 2.24 that will work. It was the last build prior to "V3" being released. I don't know the exact version number offhand.
    Quote Originally Posted by jtrosky View Post
    The 2.24 version that will work after using 3.x is 2.24.1172 (I think 2.24.1168 or higher will work). The reason is because the 3.x released upgrade the firmware in the MPVI box and only the last few versions of 2.24 will work with the updated firmware.
    Thanks you guys yeah iv got both 2.24.1170 and 1172 both work with 3.0 im wanting to download 3.2 so there will be no worries doing so.. correct ?
    And yeah i ask because i read somewhere that hptuners was going to change the firmware again i just wanted to make sure, cause i still love using 2.24 on my older projects
    Thanks again peace
  2. #362
    Aug 2011
    29
    99 c5 tire size current says 87.48?
    Cant figure out why the tire size is this high. Shifting and speedo are accurate, but if i put in 25.6 for a 275/35/18 then all is wrong. I have no idea where this number came from. Anyone have any idea?Screenshot (3).png
    I updated to the newest version this morning.
    It seems this number is closer to the circumference, [though not exactly] than anything else.
  3. #363
    Jan 2012
    26
    Also having some strange issues with the Gear/Tire Wizard... trying to change to 3.90s from stock 3.42 gearing (stock tire) but it's not working as expected and I'm not sure what's happening.
    The current value is not valid (putting that value into the first field changes the multiplier to 'ERR').
    I can input the tire diameter without any errors but the results seem suspect. Just want to make sure I'm using it correctly before I continue (garbage in/garbage out).
    3.2.40, updated 8-10-2016 @ 1900hr
  4. #364
    Mar 2010
    Texas Hill Country
    3,299
    Quote Originally Posted by S8ER01Z View Post
    you need to reenter both the tire and gear
  5. #365
    Mar 2010
    Texas Hill Country
    3,299
    Quote Originally Posted by randall View Post
    looks like circumference, not diameter.
  6. #366
    Advanced Tuner blownbluez06's Avatar
    Jan 2008
    Forney, TX
    982
    Trying to perform a segment swap on a 99 C5. The car is a manual and needs to change to an automatic. One problem is that the manual tune is a 2-bar OS, so the OSID's aren't the same. I figured "no problem, I'll just update the OS of the automatic to a 2-bar and then do the segment swap". I quickly discovered that I can't update or even view the OS of any of the files using 3.2.66.
    Hsquared racing engines RHS 427, Procharger F2, Moran Billet Atomizer injectors, Alky Control,Mast LS7 heads, Nitrous outlet kit,Tilton quad disc clutch, DSS shaft, RKT56 ZR1 trans, RPM Quaife diff. Built and tuned by yours truly.
  7. #367
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Get it figured out?
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
  8. #368
    Do we have the ability to log timing enhancement (ie. adders/tables) for flex fuel enabled vehicles in the scanner?
    '15 Colorado Z71 | '07 TrailBlazer SS | '87 Monte Carlo SS | '80 Lemans Wagon
  9. #369
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    Quote Originally Posted by motorheadmike View Post
    Yes.
    http://www.dsxtuning.com
    Just say no to bull s***.
  10. #370
    Sep 2002
    Chicago, IL
    6,397
    Depends on the vehicle.
    Easiest way to tell is just connect to the vehicle and look at the supported channels list.
    We got this guy Not Sure, ...
  11. #371
    where's the download link
    01 SS Red A4 #4987
  12. #372
    In my case it is an '07 TBSS with Flex Fuel sensor added to a 2 bar OS.
    I just double checked my Channel and I was logging Flex Fuel Advance; I wasn't looking hard enough when I tried adding it to my Chart vs. Time. Problem solved.
    Thanks, gents!
  13. #373
    Aug 2008
    Spokane, WA
    209
    Just downloaded 3.2 and I'm having problems setting up the scanner. I keep having to load my user math parameters every time I close out the scanner and reopen it. It keeps opening the default scanner it seems and ignoring what I add. It is odd because it has some of my older user math parameters from 2.25 in there. Not to mention the scanner keeps crashing when I load the new math parameters in. The channel layout keeps defaulting also. Whats the deal here?
    2000 Camaro SS M6
    11:1 Stock bottom end
    76mm Altitude compensator
  14. #374
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Sounds like it's not saving on exit like it should
    I'd try totally uninstalling and re-installing first. If problem still exists, I'd suggest contacting support
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  15. #375
    Aug 2008
    Spokane, WA
    209
    Thanks that is what I tried. I will get a hold of them.
    2000 Camaro SS M6
  16. #376
    Sep 2006
    Arizona
    600
    You report 'em, we fix 'em!
    "No job is too big, no fee is too big."
  17. #377
    Advanced Tuner Niemer's Avatar
    Jul 2012
    371
    I have a request. Would it be possible to add the ability to key through the list of graphs using the arrow keys? Or add a slider bar to that list? Right now if you select a graph title in the left column and hit an arrow key it just moves the highlighted cell. I use a 10" netbook in the car and at times the list is longer than the window and I have no way to get to the graph I want.
    Example:
    full list of graphs
    no way to access the rest of the graphs in this stiuation, which is always with a 10" screen.
    Ported TVS1900 OD cogs 10.5psi | ID850 | Vaporworx CTS-V 1:1 | COMP 219/233 .606"/.605" 113+1 | Ported TB | Pacesetter 1 3/4 LT | Solo Mach X3
  18. #378
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    There used to be a little icon at the bottom of the list that would give you access to the rest
    Not ideal in this situation but you can also use keyboard #'s, 1, 2, 3, etc. to flip through them. Only works up to 10 (0 = 10) though
  19. #379
    Nov 2006
    2,801
    Quote Originally Posted by 80gus View Post
    The ability to copy table / past table, from the the table TAB is no longer there. You have to open the table to copy/past, can we have that back it was quick easy and worked well.
    In comparison we seem to have lost parameter/ difference counter that was handy could we have that back as well?
    The ability to copy over all differences in 1 click is great but i have found I've accidentally done that twice now and there is no undo function maybe a (are you sure tab) for {copy all differences/ copy selected} as there right next to each other.
    Yes please please bring back copy/ paste table. 6LXX transmissions take so much longer to tune now. What makes it worse is the copy icon used to copy the entire table. now it just copies whatever the cursor fell on when you open the table.. same with paste.
    I've heard them say they don't want to bring back right click copy paste back because people could get in trouble.. If that's the case we should pull the timing tables out of the software too! Maybe just put up a warning when you copy/paste first time with ability to "not see this message again" Problem solved right?
    Tuner at PCMofnc.com
  20. #380
    Jul 2012
    371
    I tried this, and it would work for my needs, but it only flips through the ones that are visible on the list. If the graph is buried, it won't flip to it.
