To make the long story short, I took my car to have it dyno tuned (ID850 injectors, 11% OD pulley, headers, CAI, Ported TB, upgraded HX) on 91 octane, NGK TRIX - 574 rwhp 536 rwtq), and I'm not happy with the tune. I brought this up with the tuner, and sent a log, but he said it looked OK. The guy said to bring it back if I'm not happy with it, but Its pretty far. He has done an excellent job of tuning my old car in the past, but this one; not so much.
The issue is the drivability is poor. Log shows it is lean, as LT fuel trims are really maxed out at 25% in the lower throttle areas, particularly between 1700-2800 rpm at low throttle under load. I was told this is because of the DFCO.
I can feel the car surging. according to my wideband, it looks like its a little lean for part throttle under load when the surging happens.
If I hold the throttle steady, it actually feels like the car slows down when it gets around 2800 rpm, and from the log I can tell that the mph acceleration slows down through that range in first gear.
There is no knock.
I changed out the spark plugs yesterday to NGK BR7EF (#3346), and the problem worsened.
Can someone take a look at this to see if there is any explanation for this, possibly point me in the direction for a fix?
Thanks.
