Results 1 to 5 of 5
Thread: HELP, 2006 408 wont run correctly...
    Aug 2013
    TRAVERSE CITY MI
    3
    i have a 2006 vette motor stroked to a 408. There is a big split bank to bank. One side will pull or add fuel a lot more then the other. what is causing this? here is a log attached.
    13,564
    Post the tune.
    Aug 2013
    TRAVERSE CITY MI
    3
    2016 z71 5.3 6 speed, 295/55r20 toyo at2, 20x10 and tuned by Chris Crawford
    97 wrangler, 408 stroker, 42s, one tons, coilover/bypass shocks
    13,564
    Have you done any tuning with a wideband for the VE and MAF tables??
    You could enable your long term trims aswell, those can help determine vacuum leaks/exhaust leaks.
    Aug 2013
    TRAVERSE CITY MI
    3
    no i havent had a wideband in it yet. i will soon.
