I recently switched from the stock fan controller to a setup from D3 performance. D3 said I should be able to command 100% fans from the stock ECU and the D3 fan controller would run the spal fans at 100%. Any time I command anything over 90% the fans shut off. I know the stock PMW fan controller was limited to 90% but Im told this D3 unit is not.
This is on a 2007 Corvette with a E38 ECU.
