I believe I already know the answer to this, but 2 heads are better then 1...
My friend has a 98 LS1 harness out of a M6 Camaro and a 03 LM7 PCM. Is it possible to get the LM7 PCM reflashed so it can be used with the LS1 harness? I would say no, because of the OS on the PCM, and I do not know if the connectors are the same, Like PCM annd Harness, I will ask him in the mean time... Thanks for your time.
Or could the PCM out of the 98 camaro be flashed to run the 03 LM7 Motor? 98 Camaro is a Red/Blue PCM, and the 03 LM7 has a Blue/Green PCM. I would like to just reflash the 98 PCM to run the motor, does anyone know if this is possible, and should I just get a Tune from a 6.0 Camaro 98-00 and just flash over the 98 Camaro PCM? Thanks for any inputs!
