The polling rate for the WB is grayed out in the scanner (LC1, input 1).
Is there a way to slow it down?
No. You can average it's values over a certain amount of time if you'd rather do that (Have to create a math parameter that does it)
Are you trying to smooth the readings out or what? And what version/build are you using?
Tuner by night
CPX Tuning
2005 Corvette, M6
ECS 1500 Supercharger
2007 Escalade, A6
Stock
Yeah, I can't even read the tenths.
How do you do the average?
3.0
3.1 beta does a better job of filtering external input data--I'm not sure if that improvement has made it into 3.0 yet. Try emailing support and getting access to that and see if it helps
Do you just need it to be smoother during live logging? If so you can just use the "filter" option instead of dealing with making a math parameter. If you open the settings for charts or gauges there will be a section that says "Filter" and "ms" after it on each chart/gauge. Put in something like 200 ms and see if that helps
Tuner by night
CPX Tuning
2005 Corvette, M6
2007 Escalade, A6
Stock
Thanks I'll give it a try.
You may have to go up higher than that.. just keep in mind that it is averaging data, so it's going to be slightly delayed. It's still a heck of a lot faster than 2.24.
Tuner by night
CPX Tuning
2005 Corvette, M6
2007 Escalade, A6
Stock
That got it, thanks!
