I have 06charger R/T with p1sc1 procharge and mod
The vehicle is very hard to start hot or cold, have to give it a bit of throttle before it actually even tries to idle the PCM is adding 32+ of fuel on the trims and check engine with code 2175 .
After change the tb from arrington (85 mm) to stock the car read very lean 32% .
My fuel system is DW 72 lb/hr , BBK fuel rail and Walboro 400 lph .
What should to do ??
