Hey.
If you see in this log, when go 100% on gas, the tps doesnt go to max angle until 6000 rpm. What table should i modify?.
Hey.
Post your tune pls
it has to be some torq managment table but without the read we cant help
all the way from Tampico bay Mexico
Ok...thanks
Any advice?
Your tune file you attached is tuner locked.
So we can't access your tune file, to see what is going on.
Is this vehicle manual or automatic transmission equipped?
Are you hitting the rev limit?
You are right...sorry.
Still unavailable to open your file.
Im noob....sry. There we go.
So are you asking why it only goes to 87.5%? And no 100%?
Cause in your logs, the throttle is 100% open before 6,000rpms.
Can you also post the stock file to compare against?
What should be the right PID to observe, throttle position SAE ?
and what TM setting controls the closing and opening of the thottle like this ?, it seems in his log, when the trans shift, the TP goes from 87.5% to 34%, then comes backup again to 87.5%/
No Mark. Im not letting off the throttle. Here is another log. Rev lim is at 7200 rpm.
I am lost, what is the issue?
Can you post your stock tune file?
Mark if you see in wot pull (time line 6:55), tps is at 91.4% up to 6500 rpm and then tps goes down to 30%....rev lim is at 7000 rpm.
Raise your RPM Limit in PN, that is what is referenced when it is a manual transmission. You are hitting your rpm cutoff. Put your Torque Reduction back to stock in the Cutoff area, otherwise you will over rev.
Its a manual transmission correct?
Adjust your RPM Limit P/N, then do another log.
