So... It'd be real neat if we could use VCM Scanner to analyze data off of a Motec. See attached.
Attached file should be renamed to .csv.
http://www.dsxtuning.com
Just say no to bull s***.
List all the column names that you want to be able to plot.
You have so many, I'm only going to do the ones you need.
We got this guy Not Sure, ...
Engine Speed
Inlet Manifold Pressure
Engine Load Normalized
Engine Efficiency
Fuel Closed Loop Control Bank 1 Trim
Fuel Closed Loop Control Bank 2 Trim
Boost Pressure
Boost Actuator Output Duty Cycle
New beta up, try that. I've added a bunch of other parameter support as well.
Note that some of the MoTeC parameter names have been translated to HPT parameter names, so they will be named different in the channels list.
Also, it appears you're logging a ton of redundant parameters.
Did someone say plug and play motec?
Cool, should be nice.
What I like to call "first world problems", lol
Saw your FB post about figuring out fuel pressure messages to ECM for aftermarket regulators, that sounds pretty slick
