Results 1 to 2 of 2
Thread: 6.2 with Liginfelter launch control/timing retard.
    Sep 2013
    indiana
    65
    I was logging data on a friend's car and he has a launch control with timing retard from lingenfelter for his nitrous, while logging we were looking for the 2 degrees of timing set it was supposed to take out. I'm not seeing it, I'm wondering if I will see it in my scans. Has anyone used one of these and should I be seeing the retard in my scans thanks
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    just happened across this thread that apparently never got answered. for the lingenfelter box you will not see the timing pulled via the obd2 scanner, however it can be logged and setup using an external input through the mpvi pro. The lingenfelter has an external 0-5v output that can be logged. sorry this is late, but for anybody who happens to come across this in the future
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
