As stated I feel as though I have modified everything. Im aiming to get the car to shift at 6200RPMS but it is currently shifting at about 5600-5700. Any ideas would help.
Trialtune.hpt
Trialtune.hpt
Still missing it I guess. So lets take the 1440 in the above pic. We are multiplying that number by the gear ratio for that gear? 1440 x 3.60 or say 6500 x 3.60 . I thought you would just multiply the percentage of the rpm for engine change to the output rpm.
This should help you, but yes you multiply the output shaft rpm in the grid times the current gear's ratio. so 1.440 x 3.6 = 5,184 engine rpms.
http://www.hptuners.com/forum/showth...Tool-for-Trans
So with that being said. Why did it shift at 5600 then. LOL
Without a log, cant confirm in fact it did shift at that rpm. And when someone says "It shifted at xxx rpm" what exactly does that mean? You can log when it will start to command an upshift, and then I consider the moment the rpms fall as the shift being completed, I have never seen this be closer (usually more) than 2-300rpms to the commanded shift rpm. 5,500 would be pretty acceptable if the tune commanded 5200.
Gotcha. I have a 14 on the dyno and still shifts at 5600 EGS53
You need to raise your EOT RPM Limits under the transmission->general tab.
