Ok, I am hoping that I missed something really obvious..
My car has quite a lot of mods, in fact more or less only the ECU and the sump are left in the engine area!
Since bolting in this engine, I made reasonable progress with setting it up (more or less from scratch) and it's quite driveable, the fueling is where I'd expect (I'm not trying any real WOT stuff at this point, and the top end timing is deliberately reduced a bit).
However, I can't get rid of the idle instability. See the log. That wasn't from fully cold but you see that it swings all over the place, then when closed loop starts, it (eventually) more or less settles (but I still think it's not right, it still cycles slightly, I reduced that by tweaking the table [12483] Closed loop prop idle gain vs. 02 err...). Playing with the startup airflow doesn't help.
I've looked at and tweaked all sorts of stuff, none of it seems to make any difference to the open loop swinging? It has a 16lb flywheel and slightly bigger injectors (36's). The MAF is recurved, the injection data loaded, the VE is done in idle area at least and when driving, the fueling does what I'd expect, given my limited knowledge, i.e. 14.5-15.5:1 at cruising/general driving, around 12:1 if I boot the throttle hard & higher rpm....
Any suggestions as to what I missed?? There has to be something obvious!
Thanks in advance...
-D
