Is there something else I should be doing to get the AFR Error working with the AEM 30-0300 CAN update? I had AFR Error working fine with the NGK AFX, now swapped that out with the AEM 30-0300 over CAN, and I get mostly 26% error in all cells... seems to be working at WOT.. but not in closed loop.
Confused...
