Results 1 to 6 of 6
Thread: shift time
    shift time
    can someone explain explain the shift time settings ? i have looked at several ans cant make sense
    my 2 to 3 shift time is set at 0.300 across the board
    the problem i am having is 1 to 2 shift its still kind of hard
    at the top of chart there is
    0-40-80-120-160-200-240-280-320-360-400-440-480-520-560-600-640
    this is what i dont get i have tried 0.200 across it better but still a little hard ,, i have tried 0.650 it was worse ,, all these are in the normal setting too ,,
    can someone please fill me in
    thanks
    Mar 2007
    Tucson, Az.
    165
    need type of car/transmission
    SOLD - 2005 C6 6.0 LS2,TF 235 heads, 245/255 .630 113 LSA cam, LS7 lifters, YT 1.7 RR, FAST 102 LSXR, VMax 90-102mm, VMax CNC ported TB, LS7 injectors, Dewitts radiator, Manley 7.550 pushrods, LS7 fuel pump, PowerBond 25% UD pulley, RPM stage 2 '06+ 4:10 rear end, Callaway CAI, 160* thermostat, HP Pro custom tune, LG Pro headers
    Now - 2016 C7 ZO6 A8
    13,565
    It's a swapped car with a 5.3 or 6.0/4L60e combo.
    His tuner had set all the shift times to zero for both normal and performance and maxed out the performance shift pressure table to 90 everywhere.
    The 0-640 is a torque number, at this amount of calculated torque it will try to shift this fast is how it works.
    I would still keep the shift times to .300 but revert the shift pressure tables back to factory and see how it drives.
    i did the .300 last night in both tables ,, no change ,ill check out the shift pressure and reset i have a couple stock tunes to look at ,,
    thanks
    were are shift pressure tables ? i must be over looking them
    13,565
    It's right next to the shift time tab.
