RTT With 3.0
I can't seem to figure out how to start RTT with the new software. I tried to search, but about the only thing I can find is threads about the older version. Can someone help please? Thanks!!
Contact support and ask for the beta. It was just released.
Once you get the beta you will still need to enable it in the editor
Engine->General->Real Time tuning on the far right. You will have to decide between which group of parameters you want to have adjustment over and then write the tune to the vehicle.
After that is done you will have an option in the scanner to use it
Does this work in the old 2.24 scanner? I applied the patch to my operating system, but when I bring up my scanner, the RTT icon doesn't appear. ??
Thanks,
Dustin
Ok so I answered my own question. If you apply a editor 3.0 patch to a file, scanner 2.24 will NOT see it. So the solution was to burn the file using editor 3.0 back to stock operating system. Go into editor 2.24 and read the pcm, apply the patch using 2.24, and write entire. The scanner will then see the RTT icon appear.
Thanks,
Dustin
