Results 1 to 7 of 7
Thread: 2008 Silverado E38 ECM - no tach signal on X1 48
    Sep 2015
    Santa Rosa, CA
    55
    E38 in a engine swap. There was no wire in the 48 slot in the X1 plug. I added the wire but there is no signal. Is there a setting in HP tuners that needs to be turned on? I have rpm showing up on my scan tool.
    Jan 2013
    42
    Did you add the pull up resistor?
    Sep 2015
    Santa Rosa, CA
    55
    Quote Originally Posted by triple4x4 View Post
    Yes. I tried that. I'm getting nothing from the wire when chech I g with a volt meter. I have continuity when I check the wire end to end.
    Oct 2013
    550
    Change the Tach output from Serial to Crank.
    Sep 2015
    Santa Rosa, CA
    55
    Thanks Jon. I'll check it out.
    Sep 2015
    Santa Rosa, CA
    55
    Small update. I changed the tach to crank and now have a signal. The bad news is that now as soon as the engine fires, it pegs the tach at 9k rpm. I'm hoping I just have the wrong setting in the tach. I'll check it out tomorrow and post. Should I have also changed the resolution? If so, to what?
    Sep 2015
    Santa Rosa, CA
    55
    I found this:
    http://www.hptuners.com/forum/showth...ch-(autometer)
    I hanged the resolution and now it works perfectly.
