Hello, I'm having a problem keeping my new engine running for longer than a few seconds despite it having the VATS disabled and firing up without problem.
The engine is a 383ci. LS6, in a 2002 Corvette, with a stock LS6 intake manifold, MAF and throttle body, ported 241 heads, LG long tubes, and a Trick flow cam (112 lobe sep. 15 Degrees Overlap, 238/242 Duration @ .05, .595/.595 Lift ) I've increased Idle speed, added to the Base Idle Airflow table, and increased the timing in the Idle range, but I'm still unable to keep the car Idling.
When I start it, the engine fires up immediately to around 1,300 RPMs, then settles to about 1,000 RPMs for a second or two before dying as if it's lost fuel pressure (Scan Below) . The VATS has been disabled, but it's still acting as if something is shutting down the fuel pump. Because of this, I tried bypassing the fuel relay, and the engine fired up, started to die, but then returned to a 1,000 RPM idle and continued to run until I turned it off (No Scan File For This).
Is there any obvious reason as to why I'm loosing fuel pressure, despite having the VATS disabled? Anything else that I can try in order to get the car to idle for long enough so that I can collect some scan data?
Thanks!
Idle tune, VATS Off, Attempt 6.hplFactory Update, Verson 3.1, ETC .21 Open, idle tune 3.hpt
