p2227 silverado magnacharger
owner came for a quick tune, stock MAP, I just did the old MAF only tune but it throws code p2227. is there any quick way too change this?
every time I set p2227 to dissable my timing goes very low to 1,2 deg
thanks for your helpcon el que se fue.hptstock.hptcon el que se fue.hptstock.hpt
You've already tweaked it a little, but if you are going to run the stock MAP you will need to go higher on the Engine Diag, P2227 parameters...
With the correct MAP sensor you shouldn't have to change these at all.
