Results 1 to 19 of 19
Thread: LSA blower only making 4psi
    Advanced Tuner VodeAn's Avatar
    Jun 2012
    230
    I just want to run this by everyone and see if my thoughts make sense.
    I have a LSA blower on a LS3, the blower is 10% overdriven at the crank and fully ported w/ a 90mm throttle body, but the setup only makes 4 psi.
    Motor specs:
    stock ls3 compression 10.7:1
    stock ls3 heads
    LS6 Cam
    4" Cold Air Intake
    1 7/8 longtubes
    x-pipe
    no cats
    Now I realize that boost is a measurment of restriction and that a bigger, better flowing/breathing motor will make less boost for a given supercharger setup compared to a smaller / poorer flowing motor.
    My line of thought is that the stock LSA blower on a stock lsa makes 7-8 psi
    Adding longtube headers to a stock LSA usually makes the boost drop by 2-3 psi
    A slightly larger cam also makes boost drop by a couple psi
    A 10% overdive adds 2-3 psi
    So I guess my question is as follows:
    Am I really flowing enough air that even with my 10% overdive I'm only seeing 4 psi? I thought I'd be around 6-7.
    If so, I'm considering changing the upper pulley to spin the blower even faster, future plans include a magnuson heartbeat but I was hoping this would keep me happy for a while.
    Does anyone have data as to how much air a stock LSA blower provides at certain RPM's on stock pulley? I know I can look at logs of a stock CTS-V to estimate this but I'm hoping someone may have some flowbench data.
    I haven't checked for vacuum leaks with a smoke machine yet (because I don't have one), but I can't hear or see anything obvious.
    Jan 2016
    332
    Yeah that does seem a bit low. You've already mentioned everything that came to my mind for what might affect it. One thing you might want to look at is the bypass valve. It may not be shutting properly and letting some boost leak out. I don't have a LSA so I'm not much help on this, but I seem to remember reading some threads/posts about how the bypass valve on a LSA has some adjustments that have to be set properly. Check into that. I may be wrong.
    A good resource for you in this would be ADM Performance. They are some guru's on the LSA.
    Good luck.
    2010 Camaro LS3
    Kenne Bell 2.8 Supercharger
    BTR stage 3 PDS Torque Cam
    Frankenstein M311 heads
    9:1 forged rotating assembly
    Speed Engineering Headers
    ID1000 Injectors
    Twin return fuel fuel pump
    PLX Wideband
    HP Tuners
    Jun 2012
    230
    Thanks, I thought I set the bypass correctly, but I check it.
    I forgot to mention it has the ZL1 lid too.
    Jan 2006
    Naperville, IL
    94
    If you have all of the components of the stock bypass valve in place the bypass valve won't fully close unless the solenoid is energized (which is what happens on a LSA) or you can remove the solenoid and the bybass will work properly without any electronics.
    Rob
    2017 Chevrolet SS 6mt LSA
    Prior - 2015 Chevrolet SS 6MT LSA
    Old - 1998 BMW 540I Supercharged 402 LS2/T-56 swap
    Older - 1992 BMW 325i 402 LS2/T-56 swap
    Very old - 1995 BMW M3/ 402 LS2/T-56 swap
    Oct 2015
    6
    Do you have any pictures of it removed?
    Jan 2006
    Naperville, IL
    94
    The part removed attaches where the PCV hose is zip-tied.
    Rob
    im going with bypass valve. im seeing 10psi with my lsa blower 2.75 pulley, with ls9 cam and long tube headers.
    Jun 2012
    230
    I have the solenoid vacuum lines connected but the electrical connector is not plugged into anything.
    Okay so the consensus is for me to remove the electronic solenoid and it's lines and run only the one line you have there into the port between the rotor pack and throttle body? or remove the solenoid and still run both lines?
    If so I can do this tonight/tomorrow and report back.
    Jun 2012
    230
    Quote Originally Posted by supergt99 View Post
    What motor is the LSA blower on with that combo?
    Jun 2015
    TN
    189
    RPS Twin Carbon Clutch
    Kook's Headers
    Ported Supercharger
    Cold Air Inductions cai
    ID850's
    GPTuning 2.5 Cam
    9.1 Lower 2.5 Upper
    Mar 2012
    22
    I had the same problem after installing a ported blower with 2.5upper pulley. I removed the boost dump solenoid and plugged related ports and went from 4 to 11.5psi. This is on a 11.5:1 ls3 with 233/247 cam.
    Jun 2012
    230
    Changed to the setup rao posted,
    Running vacuum line only, it's fixed alright, I blew the tires off at 70.
    Thanks everyone
    Jan 2016
    Iraq
    16
    Quote Originally Posted by VodeAn View Post
    Thanks everyone
    I have an LS3 with LT headers and 233/248 627/610 cam , what do u think ? I will get a good boost with LSA blower ??
    thanks
    Jun 2012
    230
    What's the lobe separation angle and overlap on the camshaft? Also, will you be running stock upper and lower pulleys?
    https://www.youtube.com/watch?v=hYQ1jZ1l1tU
    There is a adjustment for this....
    Mar 2012
    Los Angeles
    62
    +1
    What cam?
    if its not a FI spec'ed cam, you are most likely boosting part of your air fuel mixture out the exhaust
    Jun 2012
    230
    Quote Originally Posted by stonemonk9 View Post
    My issue had nothing to do with the adjustment. An improperly adjusted bypass valve would not have been fixed by swapping vacuum lines around.
    The problem was I had the factory electronic control solenoid hooked up in-line, but no ECM control over the solenoid since this blower is swapped onto G8. If you hook the vacuum lines up like a stock CTS-V, but don't have control over the solenoid, the bypass valve will never fully close under acceleration. Setting up the lines like rao posted is the correct way to fix this issue.
    There is another way I discovered to fix the issue using just the pressure side, but it does not allow the bypass to open during cruise, which defeats the purpose of having a bypass.
    Feb 2010
    21
    anyone still have the pictures rao posted?
    Jan 2006
    DFW
    249
    https://www.bing.com/images/search?v...x=4&ajaxhist=0
    Hook up your bypass like this. It works correctly and will be in bypass in cruise.
    2008 Denali XL AWD LSA Blower
    2010 CTS-V
    2005 LLY Duramax SAS
    2015 Denali
