I had a question about the IFR data when using a ADM Fpcm. Car is 2 bar SD. When using variable pump pressure, say 50psi low, 60psi normal, and 65psi high. Do I flatline the IFR injector data, maybe 58psi or more, like a car with a boost dependent fuel pressure regulator? Or is it better to leave the IFR data the way it is listed in the Fuel Injector Connection data pdf, even though the rail pressure will be changing?
