Hi im new to here and a somewhat novice tuner. Can someone please look at my log to double check everything? The car runs and drives good i just installed a 2.55 pulley, Corsa intake, And long tubes all the way back to stock mufflers. thanks!!!
You might want to get some bigger injectors - these are pretty much maxing - all ready hitting 90some percent duty cycle. Your MAF could use some work - Probably need to add 4% from 5000 and less hz cells and clean it up a bit more up top unless your commanding different air fuel ratios? - Air Fuel goes from low 11's to just over 12 - could be due to your injectors maxing too? Looks like the timing for your setup is almost spot on...
Just my observations...
~Greg Huggins~
Yea i agree on the injector part my next mods will include them. How do u determine the maf being 4% low below 5000hz? And no im not personally commanding different afr. What is the standard afr variation under wot? I appreciate the help. edit lol the 4% to fix the ltft's before wot duh...correct?
Yes Same thing to fix the changing a/f ratios during wot too You'll also want to keep the MAF curve as smooth as possible... AND add as much data to look at in your logs as possible - you can never have too much info - might help you out if you run into some odd ball problem...
~Greg Huggins~
