Well, no luck with the snap on verus today... Scanner was acting screwy so didn't even try to log my vct errors with HP. Do however know that these codes set the second you fire the motor up, so definitely something position related. Also talked to the installer again today only to find out he never pulled the engine front cover, just used the wedge tool to depress the tensioner (I know from experience this pushes the chain down as you tap it in and will allow the chain to rotate on the crank - also hope it didn't screw up the locks on the tensioner?)... Then he also didn't hold the chain up while unbolting the sprocket, just allowed it to "rest" while he swapped the cam out - so most likely can bet on it being out on the crank. I developed my own way of checking and setting timing on all of GM's inline engines to verify timing because of stuff like this - made the mistake or telling GM how I did it and it wasn't two week later they came out with bulletins describing the very same method to get out of having to pay tech's time for tearing the motors down - this was back in the Colorado valve seat problem, head swap days - Sorry GM techs
SO basically I know all to well how easy it is to get these out of time doing it this way... Waiting to hear back from owner to see if he wants to tear it down or wants us to do it...
Any recommendations on cam timing once I get the problem fixed for these cams?
Thanks for everyone's help so far.
