2002 F body A4 calibration, im running a cam with 14* cam overlap and i did raise the normal and make up tables 20% and made a big difference, i have the raw fuel smell at cold start up, would think because of fuel going thru the open exhaust valve. Is it ok to make the normal and make up table the same across the table as the operating temp numbers are? Right now its 6.49 warm and 3.49 cold. It is not a daily driver and i do drive it in cold weather occasionally.
