ok long story short changed my stoich aft to 9.6 and still trys to compensate to 14.7..anything I miss?
im new at this forum how do I copy my tune to here?
this is sorry for taking so long
Have you tried enabling the flex fuel logic and filling in the appropriate flex fuel tables, so set your stoich to 14.08(assuming your're in the US that's stoich for e10). Then set stoich minimum to 9.6, and stoich maximum to 14.7. You will also want to adjust the other flex fuel tables found under "open and closed loop". From here the car will auto adjust its stoich value based on E%.
yeah I did try but I didn't spend enough time on it im sure...ill try it again tomorrow
What makes you think its compensating to 14.7 if you set your stoich value to 9.6?
Jeff Chambers, Owner
CRT Performance, LLC
349 Cleveland Road
Norwalk, OH 44857
Ph: 419-668-4151
Fx: 419-668-4643
Performance Parts, Service and Dyno Tuning Specialists
ive got a wideband hooked up to it and its not running right....
Can you set your wideband to read out in Lambda? Makes it a lot easier to tune since the ECM works off lambda as well.
Exactly. If you're trying to use a WB calibrated for fuel (and likely not even calibrated at the correct fuel stoich), then its still going to read 14.6-ish even though you're running E85 with a stoich of 9.7-ish. That's because its converting the lambda reading to an AFR based on some preprogrammed stoich value. Switch to lambda and tune in lambda.....always.
349 Cleveland Road
Norwalk, OH 44857
Ph: 419-668-4151
Fx: 419-668-4643
