When replaying a log file created with 3.0.XX the graphs populate all the data in the cells at open before playback started.
Is this normal? 2.24 populated histogram cells during playback.
When playing a log file created with 2.24 in 3.0.xx some of the PIDS recorded in the table display are not the same in 3.0.xx so not data is displayed for those PIDS.
How can you convert 2.24 PIDS in a log file to the correct channels in 3.0.xx so the data will display in the charts, graphs, and gauges?
The scanner in 3.0.xx is a big improvement compared to 2.24 but the learning curve is hard!!
